Fault codes P008b and P0627
Old Aug 12, 2019 | 06:08 PM
rravenn1313's Avatar
Default Fault codes P008b and P0627
Hello I am new to the forum so excuse me if there is already a thread for this issue.
I have a 2011 LR4 and today had the check engine light come on and at the same time a whining sound from under the rig started and continues. It sounds like a power steering pump going out but is under the vehicle and toward the middle to rear. The fault codes are P008B and P0627. Strangely it is running fine but Im sure that will change any minute. Could it be the fuel pump going out?
Any help would be warmly appreciated.
Thanks
Old Feb 26, 2020 | 04:25 PM
itiosso's Avatar
8th Gear
Thanks
Had the same issue today. Did you happen to fix or diagnose yours? What was the culprit and solution?
Thanks
ScottPNW
LR4
Feb 18, 2019 08:28 PM
OffroadFrance
Apr 21, 2014 12:20 AM
billautobill
May 17, 2010 03:30 AM
rgreenwell8962
Oct 12, 2007 09:13 PM
