Flickering headlights
Old Sep 14, 2020 | 05:13 AM
Ajhalliday's Avatar
Post Flickering headlights
My headlights flicker and there is a loud clicking noise from the region of the fuse box in the front passenger compartment, Problem was occasional but is now getting more regular. Seems to occur only after I have first driven off when the engine in cold and also when there is cold weather. Does not happen after a while on long road trips. I have had alternator replaced (genuine) in last 12 months and battery is also fairly new. No obvious problem with the fuses.
Any ideas? Thank you in advance
Old Dec 26, 2021 | 03:32 PM
kknox218's Avatar
Default Any update?
Hi! I am having the same issue. Did you ever find a resolution? I found something a while back when I first searched that said it could be the actual fuse box, but I can’t find that now. Thanks!
Old Jan 11, 2025 | 05:15 AM
markskyline's Avatar
3rd Gear
I'm also having this issue after replacing the alternator but in L405 Supercharged V8 Autobiography. Did you find a solution?
Old Jan 11, 2025 | 07:38 AM
guy's Avatar
guy
Pinpoint test 1, confirm the state of the battery. Always.
Pinpoint test 2, confirm the thrown DTCs
… which leads to pinpoint test 3.
If you’re unable to read the DTCs, I’d start with the bulbs, catalysts, relay.
Old Jan 11, 2025 | 08:04 AM
3rd Gear
I also replaced the battery when the alternator was replaced.
The audio will also cut in and out when the lights go out. I hear a clicking around the passengers foot area. Like a relay clicking. Actually the audio will cut out more frequently compared to the lights. But every time the lights would go on and off the audio would cut and come back at the exact same time as the lights. It doesn’t stay off for very long like half a second.
Only started happening after the alternator/battery replacement. It was done by my local shop. I brought the truck back to them and they cleared codes and said they had to reset some modules as they weren’t communicating. They test drove it and it didn’t flicker. When I took the truck back it started to flicker once every 5 min or so but I had my seat heater on.
Seems like it only flickers when the drivers heated seat and or steering wheel heater is on.
I’ll bring it back to them to see if they can figure why it’s happening but I thought I’d search the forums to see if anyone had a similar problem after replacing the alternator.
Old Jan 11, 2025 | 10:25 AM
guy's Avatar
guy
i mean offense….
But …
“replacing the battery” is not the same as “confirm the state of the battery”.
With the engine off and no charging device connected and no load (ignition off for at least 20 mins and doors, etc not touched). What is the voltage reading of the battery? Once this is cleared then we move to pinpoint test 2.
Old Mar 29, 2025 | 09:28 PM
Kip Hicsk's Avatar
I too am having this exact problem after a Alternator Replacement (Bosch) and new Battery. Radio flickers and headlamps flicker with the sound of a clicking relay that sounds like the passenger side.
I have:
1. Replaced the Battery a second time. (Interstate) No Luck
2. Replace the ECO battery. No Luck.
3. Attempted to isolate the Relay in the Passenger A-Pillar floorboard. (No Luck). The clicking SOUNDS like it is coming from inside the Fuseblock (Body Control Module) itself. The question becomes, is it a bad BCM, or is the BCM getting a bad signal/ground/power input that is causing it to turn off those systems.
Anyone have any new ideas?
Kip
2016 LR4 HSE Silver 3.0SC
Old Mar 30, 2025 | 10:48 PM
3rd Gear
My problem was the voltage regulator that came with the alternator. My mechanic shop found a deal on a cheaper alternator and gave it a try.
the voltage was inconsistent and always above 14v. After numerous tests they ended up swapping it for one they’ve used in the past.
since the swap to a more expensive one, I haven’t had any issues.
Hudson Miller
LR2
Feb 26, 2020 07:35 PM
wcr4x4
Dec 2, 2013 05:10 PM
honda50r
Nov 20, 2011 12:43 AM
Chevynut
Feb 13, 2009 07:48 PM
jay040472
Jun 24, 2008 12:44 AM
