Fuel rail system pressure Low and High
Old May 6, 2024 | 08:01 AM
Lumidee's Avatar
6th Gear
Default Fuel rail system pressure Low and High
Hello House
My LR4 V8 2010 give a fault code
P0087 - Fuel rail system pressure low. When the Air condition AC is off. Then when the AC is on, it gives a
P0088 - Fuel rail system pressure High
Please does anybody have an idea on how to resolve these issues.
Thanks everyone in anticipation of your response.
Old May 6, 2024 | 10:07 AM
Hugh166's Avatar
Based on the fact you are getting both codes for too high and too low I would suspect the high pressure fuel sensor on the fuel rail is going bad and should be replaced.
Old May 6, 2024 | 10:48 AM
Lumidee's Avatar
6th Gear
Please where is the High pressure sensor located. Is it also on the fuel trail. If you have pictures kindly assist. Thanks in anticipation of your prompt response.
Old May 6, 2024 | 04:48 PM
Hugh166's Avatar
It's on the back of the right side fuel rail
hlang52
May 6, 2024 10:37 PM
oliverbaer
Jul 3, 2023 10:07 AM
EdwardRRS
Apr 26, 2022 06:51 PM
Xshaunx
Range Rover Evoque
Mar 13, 2021 09:39 AM
tricey27
Jul 18, 2020 07:42 PM
