Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Range Rover Sport apparent fuel/fuel pressure issue(s)?
Old Jul 3, 2023 | 10:07 AM
oliverbaer's Avatar
Default Range Rover Sport apparent fuel/fuel pressure issue(s)?
Hello -
I have a 2011 Range Rover Sport HSE (L320) with an apparent fuel or fuel pressure issue. Mileage is 180,000. Three years ago I replaced one of the high pressure fuel pumps because it was running rough and diagnostics indicated that one of the banks was low on pressure. Fast forward three years and approximately 80,000 miles. One morning it just did not start. Fuel pressure - or lack thereof - came to mind. Diagnostics pointed to the low pressure pump. Tank was dropped and the low pressure pump was replaced. It started, ran but occasionally stalled. As a "preventive measure", the two high pressure pumps were also replaced. The apparent fuel pressure issue persisted. Tank was dropped again and the low pressure pump was found to be defective. New pump installed. Car started and ran perfectly.
Fast forward one day and the car did not start.
Any ideas on what might be causing the apparent fuel or fuel pressure issue? High pressure pump actuator? Leak in fuel system? Filter?
Thank you in advance.
Oliver
jahummer
LR4
Dec 28, 2024 07:59 AM
EdwardRRS
Apr 26, 2022 06:51 PM
tricey27
Jul 18, 2020 07:42 PM
deer40111
Aug 23, 2018 06:57 PM
Omorin34
Jan 31, 2016 10:22 PM
