Ground screw for fuse box 2011 LR4
Old Jan 22, 2017 | 11:55 PM
boysha8's Avatar
3rd Gear
Default Ground screw for fuse box 2011 LR4
Hi everyone, I bought a used 2011 LR4. I am trying to connect some internal led lighting to the fuse box, but I'm not able to find a grounding screw. Can anyone help me with a convenient grounding screw near the fuse box and how to get to it?
Old Jan 23, 2017 | 11:47 PM
BritishautoworksSD's Avatar
The interior fuse is behind the glovebox. Quite a few ground connections are under the trim panels at the floor. First remove the trim under the glovebox and then to the right, removed this trim. Under you will find many connectors and 3 to 4 grounds to choose.
Old Jan 28, 2017 | 03:05 PM
boysha8's Avatar
3rd Gear
hi, thank you for your response. I am not able to identify the exact trim you are talking about. I pulled the one on the floor just under the passenger door and there are no screws there. This is driving me nuts, not sure why I am finding it so difficult. Was a breeze on other cars.
Can you help me with a picture or two?
Old Feb 10, 2017 | 11:58 AM
boysha8's Avatar
3rd Gear
Hi, just checking back again. I am still not able to find the screws. Which exact trim are you talking about? Is it the panel on the side of the center console? If so, how can I pull it out? Is it just a yank with force?
ChrisDiscoii
Sep 15, 2012 02:10 PM
RROJ
Jul 24, 2011 07:59 AM
asmithcash4real
ROAMING WITH FRIENDS
Jul 4, 2011 07:27 PM
dr.brillo
Jun 8, 2011 06:29 PM
kcirtap
Sep 26, 2007 09:39 AM
