Hard brake pedal at start
Old Jan 26, 2014 | 09:14 PM
BritCars's Avatar
Default Hard brake pedal at start
I have a 2010 LR4 HSE which I've had for about 18 months now. I've noticed a few mornings recently when the car is cold that the brake pedal is rock solid before I start the car. I have to press it very, very hard to get the car to start - else I get the error telling me to press the brake pedal before pressing 'start'. Once the engine starts the pedal travels in like it usually does.
Any ideas what's causing this - and anything I should be concerned about? The vehicle is still on the extended warranty so if an issue brewing I'd like to know!
Old Jan 29, 2014 | 09:31 AM
LR Techniker's Avatar
Either the booster has a slight leak, bad grommet seal or faulty check valve.
Booster should be able to hold vacuum overnight.
Old Jan 29, 2014 | 08:18 PM
BritCars's Avatar
Thank you - I appreciate the guidance. Sounds like I need to take it in and have it looked at. I have the select service extended warranty so hopefully will cover it for us.
iambhooper
Sep 1, 2019 08:48 AM
Miss Rover
Jan 29, 2013 11:24 AM
cloaked96
Oct 19, 2008 10:42 AM
fordink1
Sep 20, 2007 06:45 AM
reconram
May 26, 2007 09:50 PM
