hard brake pedal/ abs light on/ slow stopping
Old May 25, 2007 | 05:58 PM
reconram's Avatar
6th Gear
Default hard brake pedal/ abs light on/ slow stopping
Replaced master cynlinder and bled brakes and installed brake fluid in my 2000 Discovery- no air in lines- now hard pedal with tendency to not stop completely- all warning brake lights are on- whats up?
Recon Ram
Old May 25, 2007 | 07:09 PM
Default RE: hard brake pedal/ abs light on/ slow stopping
Did you pre bleed the master cylinder before you installed it?
Mike
Old May 25, 2007 | 08:23 PM
reconram's Avatar
6th Gear
No. It didn't come with a bleed kit.
Old May 25, 2007 | 10:11 PM
Aquaholic's Avatar
You have to put fluid in the master cylinder before you install it - you have a bubble. Remove it and put fluid in it at an angle before you install it. Use tape or the plastic plugs that came with it to keep the fluid in while you install it.
Or maybe you have a vaccum hose not hooked up.
Old May 26, 2007 | 12:37 PM
Once you put the brake fluid in the mastercylinder, pt it in a vise and bump the master cylinder a few times to fet the air out of it, then install it.
Mike
Old May 26, 2007 | 09:50 PM
reconram's Avatar
6th Gear
Well I called Land Rover and they the ABS Modulator had air trapped in it and the only wayto get it out was with the pressure system they use. So I guess I'll take it to them on Monday.
Thanks for all the help Guys.
longjon76
Mar 6, 2021 05:32 AM
iambhooper
Sep 1, 2019 08:48 AM
BritCars
LR4
Jan 29, 2014 08:18 PM
bushpilot
May 10, 2013 02:29 PM
cloaked96
Oct 19, 2008 10:42 AM
