High idle at start up
Old Oct 9, 2016 | 10:37 AM
abran's Avatar
Default High idle at start up
I posted this in the Range Rover section, but since it's the same engine as the LR4, here it goes:
2012 sport 5.0 motor.
At start up( cold or warm) the RPMs go to 2k for a few seconds, then to 1.2k for approx 25 seconds then settle at 750-800.
I have cleaned the throttle body and reset adaptive values with no change.
Had the intake off with ignition on while my wife stepped down on the pedal smoothly to check the butterfly movement. Seems a little stalled at the beginning of the sweep, but if it is, it's so minor that I'm doubting that's what I'm seeing.
Any thoughts?
Old Oct 11, 2016 | 03:09 AM
jaguardoc504's Avatar
This seems perfectly normal to me.
On a cold vehicle the engine RPM will momentarily stay high to "get the juices flowing"
This is worse in colder climates. The RPM will stay higher even longer.
For me 30-45 seconds in the winter time (Maine).
Old Oct 11, 2016 | 05:30 AM
abran's Avatar
Thabk you for the response.
Problem is, it does this at cold start up and warm/hot start up. No matter what the operating temperature it does this.
Old Oct 11, 2016 | 11:32 PM
ktm_525's Avatar
Perfectly normal. Heats up the cats for lower start up emissions
Old Oct 14, 2016 | 12:30 AM
christianmotox's Avatar
Same here, mine does it all the time even when hot.
Old Oct 14, 2016 | 08:58 AM
abran's Avatar
Thank you for all the responses. Sounds like its normal.
Old Nov 2, 2016 | 02:14 PM
bates's Avatar
2011 LR4 did the same thing.
Old Nov 3, 2016 | 06:56 PM
Jagfixer's Avatar
2011 LR4 here too, does the same.
wick_60010
Nov 22, 2017 04:25 AM
Disco2RoverOver
May 4, 2014 10:14 PM
Sarge103
Jan 19, 2013 07:32 AM
pinkytoe69
Feb 26, 2012 06:20 AM
camaroz1985
Oct 5, 2009 01:30 PM
