questions about brake bleed
So I'm ready to bleed the brakes on my 2013 LR4 and I cant seem to find a PDF with a service manual without paying. I'm using a motive pressure bleeder.
Things I'd like to know:
Bleed sequence: is it the standard farthest wheel from the master cylinder? basically starting from the bottom of a Z. I know some cars can be finicky with the bleed order
Engine on or off: I've read in different threads it should be on
Do I have to put it in a certain mode like rock crawl when bleeding? or just leave it on the normal drive mode?
Anything I might need to do that you wouldn't need for a normal brake bleed?
Thanks in advance for your help.
-Alex
-Alex
Bled a lot of brakes and have never had the vehicle running. You're right furthest from the fluid reservoir first, working toward the nearest. Used a power bleeder, mity vac and kid or wife pushing the pedal. Honestly not sure any is better. If there is something unique to bleeding the LR4 I'm very interested to learn
flyingalexf68
May 9, 2006 01:51 PM
