Intermittent Heat - Rear Only
Old Mar 18, 2023 | 09:15 PM
M32H32IS's Avatar
Default Intermittent Heat - Rear Only
2012 US Spec 5.0 LR4 with front heater working fine but rear blows hot/cold intermittently.
What could be the cause?
Old Mar 19, 2023 | 11:02 AM
jahummer's Avatar
Could be many things, check rear heater lines after engine's warmed up, if they're too hot to touch, then there's an issue with the rear climate unit, blend door, valve, etc. If they don't get too hot to touch, then there's an engine coolant issue or air in the lines.
deemanLR3
Feb 19, 2024 06:14 PM
jahummer
LR4
Mar 2, 2023 04:57 AM
GODSDOZER
Jul 14, 2021 10:28 AM
paulblake
Feb 4, 2021 03:17 PM
Camdisco24
Nov 22, 2008 08:53 AM
