255/55R18 vs. 255/60/R18 Nitto Terra Grappler
Old Nov 11, 2010 | 02:04 AM
tuck's Avatar
Default 255/55R18 vs. 255/60/R18 Nitto Terra Grappler
Yeah, I know, another tire thread...
I'm about to buy a set of tires for my Disco, and my research is telling me that I can run a 60 series tire with no suspension modifications, or rubbing.
The tires I'm looking at are the Nitto Terra Grapplers from discounttiredirect.com. The 60 series tires are about $20 more a piece, so would it be worth the extra $80 for a little bit more height, or should I save some cash and just go for the stock size? I would like a bit more sidewall, and taller tires are always cooler, but if the difference is negligible I'd rather save the money.
Old Nov 11, 2010 | 08:15 AM
hilltoppersx's Avatar
the difference in diameter is 1 inch. that means you will gain 1/2" inch lift. if you are worried about sidewall then get yourself 16 inch rims.
Old Nov 11, 2010 | 10:51 AM
tuck's Avatar
I thought about getting a set of 16's but the stock Rover 16's don't really float my boat, and finding a halfway decent set of aftermarket rims is proving difficult. Plus I actually like the looks of the 18's.
I think my best bet would be to run stock size tires and rims until I'm ready to spring for a suspension lift, and can really upgrade.
That is, unless someone knows of a decent set of 16" rims and tires that can be had for $800ish?
Old Nov 11, 2010 | 11:42 AM
i got my tires from treadwright for $650 you can probably find 16" rims at a junkyard off a D2 for $150.
ragandhi
Nov 12, 2013 01:10 PM
aarcaris94
Jul 18, 2013 01:10 PM
Arizona man
Oct 26, 2011 06:41 PM
Disco Jo
Tires
Mar 2, 2009 01:28 PM
