LR4 - 2011 - Fuel Smell
Old Mar 13, 2020 | 04:01 AM
gaz_0001's Avatar
5th Gear
Default LR4 - 2011 - Fuel Smell
Hello,
I have a LR4 5.0 HSE 2011.
I recently started to smell fuel outside the vehicle, both when its running and when its parked up.
Unable to find any fuel marks underneath the vehicle or under the bonnet.
The fuel smell is more prominent near the rear of the car.
The fuel cap seems fine, but i did notice that it doesnt hiss when i unscrew it. Also, unsure whether it should hiss, as this was the first time i ever unscrewed it personally. My buddies identical LR4 does a hiss sound when he unscrews his.
The car seems to be using the correct amount of fuel.
Any ideas on anything i can check before i take it to the garage, or can anyone share any similar experiences and what the fault was etc.
Thanks
G
Old Mar 14, 2020 | 04:40 PM
Geo's Avatar
Geo
I had that problem with my LR3. Low pressure fuel pump cover on the gas tank gasket had split. Plenty of raw fuel on the top of the tank. Happy that it didn’t light on fire!
Its a bit of work to drop the tank, but not difficult. Price for the part isn’t terribly high. Not sure if it’s the gasket or a cracked cover.
I would try to drain or run the tank dry and drop it.
Passenger side near rear tire is where the smell will be strongest for North American cars anyway. May be drivers side if you’re in U.K.
Old Mar 17, 2020 | 12:27 AM
gaz_0001's Avatar
5th Gear
Just got word back from the garage, that no leak detected, no smell detected.
Fuel tank is ok, pressure good, purge valve is working.
But really, im sure i can smell fuel. Maybe it's the natural smell of the car running? I didnt drive this car for about 3 weeks?
Old Mar 18, 2020 | 03:37 PM
Ocean8's Avatar
I just bought a 2011 LR4, and also noticed a gas smell. Mechanic said plastic part at the top of the tank was cracked, not uncommon.
Here’s a video:
Luis Fernando Gutierrez
LR4
76
Apr 15, 2022 11:22 AM
Roben
LR4
Mar 2, 2020 08:58 AM
Ratatat
LR4
Sep 1, 2019 12:53 PM
Zach Spencer
LR4
Jun 12, 2018 05:38 PM
Kingfish
LR4
Jul 5, 2012 08:24 AM
