LR4 5.0L Metallic Ticking Sound
Old 02-13-2024, 04:03 PM
boy_the_wonder's Avatar
Default LR4 5.0L Metallic Ticking Sound
Hello good 5.0L folks,
Apologies if this post is redundant, please feel free to direct me to the appropriate thread if so.
I've recently purchased a 2012 LR4 with 173K on the clock. My initial inspection and test drive of the car led me to believe all was well with the car, but after an 80 or so mile drive home I noticed a ticking sound coming from the right side of the engine (passenger side here in the US). I know what you're thinking - timing chains/tensioners/guides. I've felt the tension of the chain through the oil fill cap, and it seems quite taught. It also doesn't seem to exhibit the trademark rattle upon startup that's usually associated with timing gear. After scouring every corner of the internet trying to find someone with a similar sounding engine, I can't seem to find anyone with the exact ticking sound I have. Perhaps you folks could offer a little insight as to what I might be hearing... I'll attach a video below. Any help would be greatly appreciated, thank you!
File Type: mov
Old 02-14-2024, 07:25 AM
nashvegas's Avatar
Received 1,252 Likes on 672 Posts
Hmmm. Tricky that one.
Bit hard to tell via a video but if not timing chain issue... I'd say it's a hopefully belt tensioner/ pulley issue up front or perhaps a slight exhaust leak at a manifold. There's something about it in the wheel well that sounds like puffing of air.
boy_the_wonder (02-14-2024)
Old 02-14-2024, 10:27 AM
I was wondering about it being a pulley issue of some kind. Perhaps I should pull the belt off this weekend and have a feel around. I’ve also heard that the two high pressure fuel pumps can go bad and become noisy. Any thoughts on that? Thanks!
Old 03-11-2024, 05:19 PM
Scottsdisco's Avatar
3rd Gear
Default Vacuum pump
From my experience on my lr4 it sounds like your vacuum pump. Mine does it when it's a cold morning start.
Androomantoo
LR4
08-07-2023 01:45 PM
MNLR4
LR4
10-12-2021 04:27 PM
rsavelkoul
LR4
01-19-2018 02:25 PM
zegil77
LR4
12-17-2017 01:20 PM
Quick Reply: LR4 5.0L Metallic Ticking Sound
