LR4 Air suspension will not lower
Old May 3, 2024 | 08:04 AM
MDLR473's Avatar
Default LR4 Air suspension will not lower
Hoping someone can help.
I have a 2010 LR4 which I've not owned for too long. The air suspension is constantly trying to raise the car to full height. The minute I tried to lower the air suspension it would throw up an air suspension fault and try to raise the car back up
The fault code read -gallery not venting. I went for blocked desiccant in the air dryer, went for the quick fix of replacing the whole compressor assy. The pump is an AMK pump. I believe this has been upgraded at some point as when inputting the reg to purchase a new pump it points to the Hitachi being fitted. I'm assuming the software had been upgraded too as the pump looks like its been fitted a while.
Replacing the pump didn't make any difference. I then replaced the forward levelling valve block in the front right wheel arch. It may have been coincidence but now it seems i can select down on the suspension height switch without it throwing up a fault straight away. It does however immediately try to push the suspension back up even with the button depressed. On initial lower selection I can hear a slight release of air which then stops. If I repeatedly select the switch it does repeat that action throwing out a small amount of air out then stopping. The exhaust valve is getting a power supply according to the code reader which very quickly shuts off. The fault code is still - gallery not venting- at this point, I did on one occasion see an exhaust valve fault but that has not appeared again.
Has anyone experienced a similar issue?
Juancl
Jul 11, 2023 11:24 AM
ovid201
LR4
Aug 14, 2022 08:01 AM
ccvalentino
LR4
Feb 8, 2022 03:18 PM
Ryan2016LR4
LR4
May 8, 2021 08:00 PM
