LR4 Compressor replacement
Old Sep 5, 2018 | 08:54 AM
James Felix's Avatar
Default LR4 Compressor replacement
I have read tons of posts here about replacing a failing compressor, but can someone answer if the Rover MUST be on a lift to swap this out? I only have a jack or 2, but not lift. So do all 4 wheels need to be off the ground to do the swap to a new compressor?
thanks!
Old Sep 5, 2018 | 09:36 PM
Geo's Avatar
Geo
I never jacked up the truck when changing mine. But it wasn’t in Access height mode. The compressor is small, so if you can fit your head under the truck to see the bolts, should not be an issue.
Old Sep 6, 2018 | 10:25 AM
Default ok but
I would think the air would then leak from the system and drop while you were doing the swap no?
Old Sep 6, 2018 | 11:11 AM
Geo's Avatar
Geo
I never noticed air escaping, I believe the valves (if functional) prevent that. Plus, even Access Height, is not that low.
Old Sep 6, 2018 | 08:08 PM
abran's Avatar
The valve blocks hold the air for the corners.
Old Sep 12, 2018 | 09:35 AM
OK so I did the compressor replacement last night, it took about 1 hour, the job would take 30 minutes if it were not for 1 of the bolts to remove the compressor bracket being impossible to get to much less remove. I bought a cheap China Hitachi style compressor off of ebay instead of a 1100 dealer part. IT was an exact match in size and mounted right up. The only difference I can see between the stock on and this one is the slight noise it makes like a cheap 12v air pump when adding air to the system. All in all the dealer wanted 1500 bucks, what a joke...
Old Sep 12, 2018 | 09:40 AM
Thank you Geo and Abran. I also bought a drier rebuild kit fro 40 bucks to fix my old compressor should this one go bad...
Old Sep 12, 2018 | 09:46 AM
Here is some step by step directions to help you out and a video that shows you how to remove.
Link to instructions
Tools needed to swap Compressor
10MM socket and driver with long extension and flexible coupling.
30Torx
10MM wrench, longer the better to remove the difficult bolt.
Old Sep 12, 2018 | 09:56 AM
Here is the LR4 back to full strength with new wheels...
jafir
Aug 12, 2021 08:36 PM
05TurboS2K
Aug 7, 2019 07:47 PM
Baumer22
Mar 20, 2018 06:24 PM
rphotographer
Dec 21, 2008 06:25 PM
swrye
Mar 31, 2007 02:33 PM
