Lr4 doesn't like being in drive anymore
Old Apr 9, 2021 | 05:35 AM
Matthew John Stuart's Avatar
4th Gear
Default Lr4 doesn't like being in drive anymore
Hello everyone, first post on the forum!! So, yes when trying to select drive, gear slowly pushes itself back to neutral, from what I understand a linkage seizes up, is it a relatively easy fix, or could there be more too it?!
Old Apr 9, 2021 | 07:11 AM
PaulLR's Avatar
Try this $40 repair first. It made my shifter feel like new again.
https://www.roverparts.com/transmiss.../TRANSLINKIT1/
Old Apr 9, 2021 | 07:34 AM
DakotaTravler's Avatar
Try lubricating it. Mine was doing the same, sprayed some silicone lubricant on the linkage and its been fine - I reapply every year. I have the kit above but never installed it yet.
Old Apr 9, 2021 | 04:49 PM
4th Gear
Thanks Paul, for the information on the parts 👍🏻
Old Apr 9, 2021 | 04:51 PM
4th Gear
I’ll give this a try thanks DT, is it easy to access, just one panel to remove, to get at it?!
Old Apr 9, 2021 | 04:52 PM
4th Gear
Thanks Paul for that information 👍🏻
Old Aug 15, 2022 | 06:49 PM
LS79's Avatar
How far did you drive before lubricating the first time?
Last edited by LS79; Aug 15, 2022 at 06:52 PM. Reason: delete please. Did not address the author. thank you
Old Aug 15, 2022 | 06:50 PM
LS79's Avatar
How far did you drive before lubricating it?
dlonesty
LR4
Mar 31, 2021 10:33 AM
mmbirtcher
LR4
Dec 27, 2020 07:30 PM
LeakyDisco
LR4
Feb 10, 2018 01:07 AM
iconoclast
LR4
Nov 16, 2017 07:20 AM
markrblack
LR4
Jul 29, 2016 05:39 PM
