LR4 Oil Level indicator problem
Old Oct 18, 2020 | 08:15 PM
rogerh's Avatar
Default LR4 Oil Level indicator problem
I recently bought a 2012 LR4. I went through the 70,000 mile update where I changed the oil amongst other things. I used the recommended 5-20 wt. Mobile 1 oil (now on sale at NAPA, by the way). When I was done draining the oil and replacing the filter, I filled it up with 8 quarts as recommended. Unfortunately there is no oil dipstick on the LR-4 so you are forced to use the dashboard indicator. Here’s the problem - after adding 8 quarts, it shows that the level is ‘MIN’, and on the right of it, the indicator says ‘Not Available’. What does that mean?
I’ve enclosed a screenshot so you can see what I mean. Landrover is the second company that I’m aware of that’s eliminated the dipstick. Why I don’t know but I think it is really stupid. I had an X5 with the same issue. So I’m forced to assume that I don’t have enough oil in the LR4. Has anyone else seen this?
[img]blob:https://landroverforums.com/a81a5a60-bf23-4c6d-8176-e73541de6e6f[/img]
Old Oct 19, 2020 | 06:06 AM
jeffh's Avatar
If not mistaken its 8.2qts. You need to open the filter first before draining, this will drain upward of 1/2qt. from the filter housing. If your digital readout is showing "min" add 1/4qt. check again. add a bit more. if need be. Also in the future its bet to use a mitivac. This gets the most oil from the system, as well as allowing you to measure how much you have extracted.
Old Oct 19, 2020 | 09:39 AM
alegrianyc's Avatar
Ah yes the awesome digital oil gauge. I have a 2012 and do my own maintenance (with the mitivac as well) and it takes it sweet time to get a reading. Eventually, sometimes even the next day, is when it decides to. Check it again the next day or two.
Old Sep 10, 2022 | 08:56 AM
joeofdetroit's Avatar
Default Too much oil
I recently purchased a 2012 LR4. Wanting to check the oil I read the manual and did the electronic sensor. Having just turned off the auto the not available note came up. It showed oil at min. I purchased two quarts of oil and put them in the car. I reread the manual and determined your engine must be off for at least 1/2 hour. The first two days I checked it showed at the top of indicator. Today it said “ overfilled”. However the overfilled light did not come on.
What should I do?
Jason Anzaldua
Jan 7, 2022 07:56 AM
Russell J Russell
Oct 18, 2020 08:26 PM
LRFower
LR4
Oct 1, 2020 08:51 PM
brokentruck
LR4
Sep 7, 2016 07:13 AM
scottdegelman
LR4
Mar 10, 2014 09:10 AM
