New Brake Pad Sensor, But warning still on
Old Sep 11, 2022 | 04:38 PM
jlazyr@gmail.com's Avatar
7th Gear
Default New Brake Pad Sensor, But warning still on
We have a 2013 LR4. The brake pad sensor light came on. Front brake pad sensor wire was broken. Replaced it with a new one, but the brake pad sensor light will not go off. I had a similar issue when I changed the rear sensor a while back, but after messing with a connection a bit the light went out. No such luck this time. Unplugged and reattached sensor several times, made sure both ends were clean and made sure it was properly connected to the brake. Light is still on. Any suggestions?
Old Sep 11, 2022 | 05:24 PM
NJOverland's Avatar
It may just be a stored code that would need to be reset.
Old Sep 11, 2022 | 06:40 PM
7th Gear
Thank you.
Oceanguy33
Feb 10, 2022 03:55 PM
Giusepd
Dec 6, 2015 01:12 PM
Titus
Oct 19, 2015 11:40 AM
tims911
Feb 25, 2014 07:28 PM
sn1987
Defender
Nov 10, 2009 11:38 AM
