LR4 pre purchase checklist
Old Sep 25, 2025 | 03:25 PM
  #21
Richard Gallant's Avatar
Ok your 2 biggest issue are coolant and oil.
Question One when was the coolant last changed if never then you will being very likely be looking a plastic cross over pipes - you can check the PH if in doubt
Question Two does it use any coolant - a shot glass or less over 500 to 1000 to mile is fine, more could be an issue
Question Three how often do you change the oil,if they have to think or say as recommend timing chains are in your future 3000 to 5000 miles is your oil change range
Finally and this applies to any used vehicle examine it closely you don't care how clean it it is, how do the brake rotors look,are they grooved, Check the tire wear even or not - new cheap tires are generally a red flag. Check the carpets are they dry is there any musty smell. If you get a vehicle where teh owner has skimped on maintance you will have problems.
The only thing that you can ignore it the start stop battery, lots of people hate that feature and leave the battery dead, myself included.
Old Sep 28, 2025 | 07:50 AM
  #22
guy's Avatar
guy
To add to Richard’s good summary post:
Firstly, I for one do use the stop/start feature.
Secondly, this a big, heavy, complicated vehicle therefore absolutely, if you are not technical head in to a dealer or specialist and get it looked at.
There are many components, PTU, EPB, drain hoses, brake lines, rust points, not being able to be 4wheel aligned, BUSHINGS… the list goes on.
Old May 22, 2026 | 12:10 AM
  #23
SeaCruiser's Avatar
Originally Posted by Pwd3
Sounding great until no heated seats, that is a deal breaker with the wife. I don't know why LR would bother deleting than from the build. An essential for some folks with dodgy backs.
What are you asking?
Old May 31, 2026 | 09:47 AM
  #24
Gnomadf's Avatar
I have a question for Michigan LR4 owners-how much is your registration? The SOS sent my renewal and it's $246 for a 2008 LR3. I'd like to upgrade but now I'm concerned abou how much my tags will be for an LR4.
mbaliatico
LR4
Jul 1, 2021 08:30 AM
ZB-30
LR4
May 12, 2016 12:00 AM
2000_328ci
LR4
Sep 30, 2015 12:57 PM
Iron oak
LR4
14
Sep 11, 2014 07:33 PM
6SpeedBowtie
LR4
May 21, 2013 10:27 AM
