LR4 Rear Windows stopped working. Fix below.
Old Nov 13, 2019 | 02:40 PM
GradyB's Avatar
6th Gear
Smile LR4 Rear Windows stopped working. Fix below.
After having had a dead battery the rear windows would not lower or raise. Tried resetting using the window switches to reset auto up and auto down. No luck.
I pulled fuse 39 and 44 in the fuse block behind the glove box and the windows now work again. Then with windows rolled up, held switch in up position for a few seconds and auto up and down work.
That's it. Hope this helps someone.
Here's another interesting discovery (no pun intended)... Before I discovered that the rear windows were not working the alarm system would not arm. It would just beep twice as if I had left a door, bonnet or tailgate open. I assumed it was a bad bonnet sensor as I had this problem with my LR3 I owned previously. Well, after resetting/rebooting the rear windows, the alarm system once again works. So pulling those fuses fixed both issues.
The only remaining mystery is why the battery drained in the first place. It is a one year old Absorbed Glass Matt (AGM). We were gone for about 10 days and upon our return the battery was completely dead. I put it on a charger and it's been holding a charge since. The only anomaly was a very slight amount of corrosion on the positive terminal.
Old Nov 14, 2019 | 05:49 AM
LR Techniker's Avatar
Grady, Thank you for posting that. Its a very interesting find, and glad somebody had a similar experience as me.
We had an LR4 doing the exact same thing and with the tester connected, we had no communication with either back door. We had disconnected the door pass-through to check for Power, Ground and LIN-Bus activity and all was good. Once re-connected, the windows started working.
We were not sure if it was a connection problem that was restored once disconnected/reconnected or the Door Modules just needed a "reboot". Your post confirms it just needed a reboot and pulling the fuses is a simpler way to achieve this.
Well done!
Old Nov 14, 2019 | 11:59 AM
GradyB's Avatar
6th Gear
Well done!
Thanks. Here's another interesting discovery (no pun intended)... Before I discovered that the rear windows were not working the alarm system would not arm. It would just beep twice as if I had left a door, bonnet or tailgate open. I assumed it was a bad bonnet sensor as I had this problem with my LR3 I owned previously. Well, after resetting/rebooting the rear windows, the alarm system once again works. So pulling those fuses fixed both issues.
Old Jul 27, 2020 | 09:41 AM
kthhrrsn's Avatar
4th Gear
Thanks Grady! I have a 2013 LR4, and I'm having the exact same issue after a battery drain. I planned to make an service appointment at the dealership, but I will try this first. I'm hoping it'll save me several hundred dollars! Another thing that I've noticed since the batter drain issue is that my side mirrors no longer fold in when I lock the activate the alarm. I assume that's related to the alarm not actually activating and beeping twice instead.
You're a real life saver!
Thanks,
Keith
Old Jul 27, 2020 | 11:13 AM
GradyB's Avatar
6th Gear
Default Battery drain cause.
Glad to hear this was helpful.
I solved the battery drain mystery. I had altered the settings on my dash cam and that little device sat there and drained the battery in 10 days time.
Old Jul 27, 2020 | 12:22 PM
kthhrrsn's Avatar
4th Gear
It worked like a charm! I'm back in business. I'm glad you solved your battery drain issue. My problem was that my wife accidentally turned the lights on (manual mode) and didn't realize it. 2 days later, when I went to use the car, completely and utterly dead.
Old Apr 6, 2021 | 09:43 AM
pettynerd's Avatar
Wow, this was a quick fix!
Thanks for the info Grady!
Old Apr 6, 2021 | 11:05 AM
GradyB's Avatar
6th Gear
Glad to hear it, happy I could be helpful.
Old Mar 16, 2024 | 07:58 PM
RobManSP's Avatar
Default Thanks!
Hi! Thanks! Just registered in the forum to thank you worked flawlessly!
devildollnyc
Jun 1, 2020 01:59 AM
Erika Apicella
Sep 29, 2016 09:21 AM
Motorvated
Aug 16, 2013 10:30 PM
llPANCHOll
Apr 22, 2009 02:53 PM
95discotn
Oct 13, 2004 09:28 PM
