Lr4 starter issue. Need help!
Old Sep 28, 2019 | 11:24 PM
Rellleonis1's Avatar
Default Lr4 starter issue. Need help!
Okay so I recently had to do a gasket job, timing chain, and valve job on a 2011 Lr4 because it jumped timing due to the chain guide issue. I finished the job and went to try and start the engine and to my luck nothing just a single click. My first thing I did was check the engine to make sure it turned freely and it did. Then I swapped the relay for another one I know was working to make sure that was not the issue. Then I checked the battery and it was good but I replaced it anyway since I planned on doing that anyway. I then purchased a new starter and installed. Went to start the engine again and same symptom. I am at a loss now in trying to figure this out. Does anybody know what this can be?
Old Sep 30, 2019 | 06:55 PM
LR Techniker's Avatar
My guess would be you left a ground cable loose doing the timing chains. If you hear a "click" from the starter (and its not something like the throttle body resetting), then the KVM, pushbutton, CJB and all that is working (it is saying its "OK" to crank). Then the fault is either power or ground to the starter.
My first guess is that you left the TDC pin on the flywheel, but if it turns freely, then its not that.
Old Oct 1, 2019 | 11:46 AM
abran's Avatar
Check the Fusible link on the positive battery cable.
Also you can jump the contacts directly at the relay socket to confirm that it's not a relay issue.
Old Feb 12, 2025 | 09:56 AM
sjones81's Avatar
Default Did you find a solution?
Hello Rellleonis1. I ran across this thread because I just finished a similar job on my 2012 LR4 and am seeing the same result. Only a click when trying to start. Did you ever resolve the issue? If so can you please share what you did? Thanks.
Old Feb 12, 2025 | 02:12 PM
guy's Avatar
guy
Define "battery is good"?
Cheers!
Old Feb 13, 2025 | 11:48 AM
sjones81's Avatar
Default New Battery
Cheers!
“Battery is good” means brand new battery. Thanks
Old Feb 13, 2025 | 01:39 PM
guy's Avatar
guy
Apologies @sjones81 , what I meant was "is the battery operating properly?"
Age is no indication of battery health.
With the engine cold and not running, and with no charger attached for a minimum of 6 hours, what is the voltage reading of the battery?
A battery that reads 12.4v maintains less than 50% of capacity. And that is not sufficient for this vehicle. (Assuming you are using the properly sized battery).
All I'm exposing is that from the workshop manual, this is pinpoint test #1. Once we can rule it out, we move forward to the other tests.
Additionally, what codes are being thrown?
Cheers.
CB7010
LR4
19
Nov 17, 2022 10:11 PM
Flexi98ss
LR4
May 21, 2019 06:41 PM
john_greg
LR4
Nov 7, 2018 01:33 PM
Lr4russian
Mar 3, 2017 06:56 AM
glovings
Feb 17, 2010 06:17 PM
