LR4 V6 engine vs Jaguar V6
Old Jan 21, 2023 | 07:49 PM
steevo67's Avatar
Default LR4 V6 engine vs Jaguar V6
I happen to be in need of a replacement engine for my 14 LR4. There aren't a whole lot of LR4 engines locally, and the LR4 3.0 is more expensive than the 3.0 out of a Jaguar. I'm wondering if anyone knows what the difference is between the engine out of an LR4 and an F-Type or XF? Looks like some of the accessory drive brackets & pulleys, and the oil pan, but looking for someone who has actual knowledge.
Old May 9, 2024 | 10:27 AM
Jmfawson's Avatar
Default Any update
im in the same position. Were you able to find out if the F type works on the LR4 and what changes needed to be made for it to work? Thank you!
Old May 10, 2024 | 10:21 AM
CincyRovers's Avatar
That is correct. Some of the accessories are waterproofed for a higher wading depth and the oil pan is different so it can go up and down steep inclines without starving itself of oil. Other than that, they are identical.
M32H32IS
LR4
May 29, 2023 07:50 AM
hawaiianbarbecue
LR4
Jan 8, 2023 04:09 AM
Luke87GT
LR4
Nov 22, 2022 08:09 AM
dlonesty
LR4
Mar 31, 2021 10:33 AM
iconoclast
LR4
Nov 16, 2017 07:20 AM
