Multi-Error (P0528, P2169-13, P0483-36, etc)
Old Jul 9, 2022 | 11:09 AM
Borromeonyc's Avatar
Exclamation Multi-Error (P0528, P2169-13, P0483-36, etc)
Hi, I'm hoping some experts can steer me in the right direction with my 2016 LR4 (67k mi). I just did my 64K service (change oil, air & cabin filter), but the shop didn't clear the "needs service in xxx miles" code. Before I got the chance to bring it back in, the needs service lapsed. The truck was/is running well, but out of the blue, I got the Check Engine light last week. Scanner threw back these errors and I'm trying to figure out the pattern so I can isolate the problem.
Errors:
1. P0528-00 - Fan Speed Sensor circuit no signal.
2. P2169-13 - Exhaust pressure regulator vent Solenoid control-circtuit - Open
3. P0483-36 - Fan Performance
4. P0162-00 - 02 Sensor Circuit, Bank-2 Sensor 3
5 P0062-00 Heated oxygen sensor heater control circuit [Bank-2, Sensor 3]
6, P0333-22 Knock sensor 2 - circuit high input [bank 2]
7. P0089-64 Fuel Pressure regulator performance
NOTE: The shop cleared all codes on Thursday thinking it was a fluke, but the check light just came back on today (Saturday).
Anyone see this before or maybe sees a pattern here? I'm trying to find out what could possibly be linking all these together to throw so many codes at the same time.
Thanks,
Ben
Old Aug 31, 2022 | 07:37 PM
KomarmyLR4's Avatar
I have similar Codes (Fan Bank 2 Sensor 2, Bank 2 Sensor 3 + mass air flow sensor) - Cleaned the airflow sensor and it is OK. I ordered new sensors and Bank 2 rear (blue cable and connector) went in no problem, Bank 2 center sensor has a white cable with light grey connector. (it is on the Catalytic converter) I got a replacement part and it has black cable with dark grey connector and it did not clip into the connector on the car. Any suggestions?
erick846
May 14, 2020 12:55 PM
BFox15
Aug 10, 2011 10:35 AM
wlbannister
Aug 6, 2011 06:07 PM
88Mwife
Jul 18, 2011 01:00 AM
*RANGER*
Mar 12, 2008 05:17 PM
