Need Help -2012 LR4
Old Jul 16, 2021 | 06:30 PM
Fake Mechanic's Avatar
Default Need Help -2012 LR4
Hopefully you guys can help me. 2012 LR4 HSE. Basically, I have a p0442 evap code, but that’s not all folks. Gas tank farts about every 20 seconds because it’s not …
changed the purge valve. Nothing
I’m trying to get the canister out to see if it’s clogged so I can run some air but I can’t figure out how to get tge damn thing out. Plate covering it. I’m a novice. Can I run air through it while still attached to the lines?
Old Jul 17, 2021 | 02:04 PM
jlglr4's Avatar
P0442 is a code for a small leak in the evap system. Do you have any other drivability issues? When you say it farts every 20 seconds, you mean just sitting it’s letting pressure out the cap?
Fuel cap leaks are the most common cause for this code. Maybe start there if you haven’t already replaced.
I don’t have the procedure for the canister removal, but I remembers seeing some posts or videos. Maybe search/post over at landroverworld.org.
Old Jul 26, 2021 | 12:50 PM
abran's Avatar
Besides purge valve the DMTL pump can cause that code.
Old Oct 31, 2021 | 06:05 PM
kjnmontana's Avatar
3rd Gear
JLGLR, do you have any remove and replace the evap detection valve resources you can steer me towards?
thanks
Old Nov 5, 2021 | 12:29 PM
abecruz24's Avatar
here is a vieo on that DMLT pump hope this helps
Giverny03
LR4
43
Aug 27, 2025 01:00 AM
Collin Wickes
Apr 7, 2019 08:13 PM
iconoclast
LR4
Nov 16, 2017 07:20 AM
omega48er
LR4
Jun 21, 2017 10:35 AM
Kingfish
LR4
Jul 5, 2012 08:24 AM
