questions about brake bleed
Old May 22, 2018 | 03:56 PM
Axelander's Avatar
Default questions about brake bleed
So I'm ready to bleed the brakes on my 2013 LR4 and I cant seem to find a PDF with a service manual without paying. I'm using a motive pressure bleeder.
Things I'd like to know:
Bleed sequence: is it the standard farthest wheel from the master cylinder? basically starting from the bottom of a Z. I know some cars can be finicky with the bleed order
Engine on or off: I've read in different threads it should be on
Do I have to put it in a certain mode like rock crawl when bleeding? or just leave it on the normal drive mode?
Anything I might need to do that you wouldn't need for a normal brake bleed?
Thanks in advance for your help.
-Alex
Old May 22, 2018 | 09:49 PM
Greggles's Avatar
Bled a lot of brakes and have never had the vehicle running. You're right furthest from the fluid reservoir first, working toward the nearest. Used a power bleeder, mity vac and kid or wife pushing the pedal. Honestly not sure any is better. If there is something unique to bleeding the LR4 I'm very interested to learn
schwaggy
Jul 14, 2017 09:34 AM
LR03NJ
Mar 10, 2016 12:35 AM
JavaDiscoII
May 29, 2010 04:33 PM
ste
Mar 23, 2007 06:47 PM
flyingalexf68
May 9, 2006 01:51 PM
