Rear Brake rotor/Drum and EPB Service Mode LR4
Old Aug 31, 2016 | 06:42 PM
Boxcars's Avatar
Default Rear Brake rotor/Drum and EPB Service Mode LR4
I have 2010 LR4 HSE,
as anyone install new rear drum/rotors on the 2010 LR4? also EPB shoes?
Do you have to put the EPB in service Mode?
How do you put EPB into service mode?
Is Diag software required? If so what are you using?
Stated in Brake Bible
Before removing the rear Brake disks, please carry out this sequence to put the Electronic Park Brake into Service Mode. Ensure brake pads and calliper is fitted to all wheels. In the car with ignition in Position II, press the brake pedal three times and hold the pedal down. Push down on the EPB switch for 3-5 seconds.
Go to the main fuse box in the engine bay and remove FL8 fuse 30A (pink Fuse) this will ensure that the EPB is not accidentally re-engaged.
Thanks
Old Aug 31, 2016 | 06:43 PM
Boxcars's Avatar
Sorry if this is in a thread, I have searched and have not figured it out for the LR4
(No key, Start/Off button)
Old Oct 5, 2016 | 07:57 PM
LR Techniker's Avatar
I'm late to this party, do you still need help?
Also note that if you replace the rear rotors, you need to re-burnish the park brake shoes (in case you have not yet).
angasreid
Dec 16, 2023 07:45 AM
TEX_Rover
Aug 28, 2017 12:46 PM
bcolins
Feb 9, 2014 08:35 PM
transpartstech_rover
Mar 2, 2010 02:13 PM
