Rubber floor lining?
Old Jun 6, 2019 | 06:31 AM
SundayFunday's Avatar
Default Rubber floor lining?
Curious if others have approached floor lining with say some custom rubber liner to rid soggy carpet?
fixing some frame punk- and as I’ve peeled some carpet up - this case is rear cargo area to get to fuel pump to drop tank, where the carpet and sound deafening material is soaking wet. It’s from sunroof drains - which will be addressed next - but im not sure I want to put the original liner back in there..
cutting out rear cargo carpet entirely can be an easy option - and a rover load mat seems to be a hens tooth. People thing they’re gold plated.
Just wondering if anyone has used a custom rubber mat in a similar execution?
BecauSe inevitably- the front foot wells and even b pillars floors are going to be similar condition I assume.
its not too bad yet (not nearly as bad as I expected) under carpets- but the water pouring in as of recently is going to cause problems soon.
Old Jun 6, 2019 | 10:54 AM
miron's Avatar
I was looking to do the same on my Disco (no leaks, just the carpet gets filthy after every couple of trail trips). I couldn't find anything that would be already pre-made, but if you search youtube you can find some DIY solutions on how to mold vinyl flooring sheets (you can get those in any color with a bunch of different textures) to match the wheel wells, etc. I've also replaced the (gross) foam padding with Dynamat.
Old Jun 6, 2019 | 02:51 PM
FlyingZebra34's Avatar
I've toyed with the idea for awhile. I've done bed liner in Jeeps before. Big thing is how much noisier the cab gets, and how much warmer/colder it gets. That 2-3" foam piece on the carpet does some good work keeping the cabin insulated from noise and the elements.
Old Jun 6, 2019 | 06:23 PM
Extinct's Avatar
Why not get a good replacement from a southern truck breaker?
Old Jun 6, 2019 | 06:46 PM
XRAD's Avatar
Carpet and sound reduction material removal = more road noise will be heard....if that bothers you.
Old Jun 6, 2019 | 07:02 PM
miron's Avatar
I take easy to clean rubber over 20 year old carpet
Old Jun 7, 2019 | 06:19 AM
I understand the noise will increase- which always seems to get much louder then you anticipate.
perhaps lining it with bedliner or a rubber seamless adhesive to coat the floor - then..
Dunamatt is an expensive approach I would assume.
must be something more recycled or install friendly
me 2
Nov 14, 2013 07:30 PM
brettguise
Mar 5, 2013 07:33 AM
Jason Andrew
Nov 19, 2012 01:49 PM
dnorrell
Mar 18, 2010 05:23 AM
Sniper
Apr 7, 2007 12:28 AM
