Smoke after cranking harsh smell 2014 LR4 SCV6
Old Nov 12, 2021 | 11:15 AM
jlglr4's Avatar
Actually, the leak down test I was referring to is introducing pressurized air into the cylinder at top-dead-center to see if it holds. If it leaks air, listen for the leak through the intakes, adjacent cylinder, oil filler cap, etc. Testing the coolant for exhaust with a chemical agent is another relevant test that can be performed, but with the coolant having been mostly drained at this point and the system unpressurized and open, not sure if that would work anymore.
Old Dec 4, 2021 | 06:54 PM
abecruz24's Avatar
okay i have put it all back and now the engine wont turn over , the starter is doing its job its cranking just not starting. any help with what can i do . also i did put the ODB2 and i seen it had a fule disabled not sure if i need to enable the fule pump some how or ? i do here the fule pump come on when i just turn it on (with out break pressed) HELP!! thank you
Old Dec 4, 2021 | 10:31 PM
jlglr4's Avatar
You say the OBD2 says it has fuel disabled. Can you provide more info - is there a code showing in the scanner? Did you have the fuel pump fuse pulled to run it out of gas when doing the repair?
I also remember one instance where someone mixed up the heater manifold diverter plug with the coolant temp sensor plug. Might check to make sure these didn’t get switched accidentally. I think both are on that rear crossover pipe.
Old Dec 5, 2021 | 01:48 PM
abecruz24's Avatar
I did not remove the fuse of the file pump. will this cause terrible issues . And the code I seen for the file pump I don't remember what I did to pull it up or get back to it. And I will check the connection but sure I got them right.
Old Dec 5, 2021 | 02:33 PM
abecruz24's Avatar
Looking back I did see that there are two connections that just ended one look to be a temperature sensor and other one some other kind of sensor possibly but it also looks like the cable are just missing. But when I was as connecting them I don't remember having to see and lose wires. Please look at pic . The right circle is the temp sensor and the left bottom is the connection that looks like it's missing wire's but may also be a sensor. The blue arrow is the cross over coolant pipe. Thank you for helping me out
Old Dec 5, 2021 | 04:20 PM
jlglr4's Avatar
Sorry - I can’t tell anything from this pic. I think the socket with the blank plugs (right circle) is just not used - those look like the little blanking plugs they put in to prevent corrosion. I cannot tell what the other plug (left circle) is for. I just recall that this was the area where some other forum member had swapped two plugs and the car wouldn’t start. Towed it to the dealer and they figured it out.
But, this might not be your problem. Reading back through the posts, looks like the last time you tried to start it before taking it apart, the truck “cranked/rumbled” before pouring out smoke. So, there might be something else going on.
As for the fuel pump fuse - I mentioned it only because its one way people release fuel pressure before disassembly - remove fuse and run it until it stalls. Sometimes people forget to put the fuse back in. No harm if you didn’t remove it.
Wish I had some other ideas for you. Check for spark, check for fuel (wet plugs).
mirepoixmatt
Dec 16, 2013 10:30 PM
pedro_malo
Jan 14, 2012 08:30 AM
rcrosby
Mar 22, 2011 05:03 PM
XxRoverAllOverxX
Sep 25, 2010 05:12 PM
Bensun
Jul 22, 2009 04:48 PM
