Vibration at 50 MPH in 2011 LR4
Old Dec 31, 2021 | 03:38 PM
LR4thewin's Avatar
Default Vibration at 50 MPH in 2011 LR4
Hi all, I have a 2011 LR4 5.0 V8 with 140K miles.
The entire car shudders, like a heavy vibration, as I pass through about 50-55 MPH on a flat highway. If I am going up a slight grade, the shudder will happen at a higher speed.
It is very noticeable, and it lasts about 2 seconds. It almost sounds like driving over rumble strips. I can't seem to keep the car vibrating by finding the exact speed. It always comes and goes.
Any thoughts? Thanks!
Old Jan 1, 2022 | 07:49 AM
jeffh's Avatar
a tire has a bad spot, out of balance, when was the last time you rotated your tires. Check the rear drive shaft center bearing for any "extra" play. Check all your front steering and suspension parts.
It could be one of these.. or none of these. But you need to start checking...
Old Jan 3, 2022 | 08:33 AM
LR4thewin's Avatar
I'll check on these. Of course I would prefer it to be a tire rotation issue, but I think it might be something more complicated. What do you think about torque convertor shudder? Thank you!
Old Aug 17, 2022 | 08:05 AM
LR4thewin's Avatar
I still haven't been able to resolve this "shudder" at 50-55 MPH. I've put more miles on the car. Does anyone else have any thoughts?
Old Oct 2, 2022 | 11:44 AM
LR4thewin's Avatar
Based on another thread, I just had my local independent do the transmission service / fluid change -- and there is definitely significant improvement. This has also improved RPM fluctuations at highway speed.
Matt Redd
LR4
Dec 11, 2021 02:54 PM
Trevorn
LR4
Nov 18, 2020 05:59 PM
Axelander
LR4
14
Oct 23, 2019 08:09 AM
Shaky Disco
LR4
Aug 30, 2019 05:53 PM
blapp
LR4
15
Jun 1, 2016 02:52 PM
