Where does this connector go?
Old Dec 29, 2021 | 06:01 PM
jahummer's Avatar
Default Where does this connector go?
Recent AC rebuild and this harness in sitting loose and unattached. Looks like it should go somewhere. It's on the left side of the fan shroud near the radiator, thermostat housing, transfer case breather and coolant overfill tank.
Old Dec 30, 2021 | 09:29 AM
jahummer's Avatar
It's the fan harness if that helps.
Old Jan 12, 2022 | 11:41 AM
rsquared's Avatar
4th Gear
Default Fan connector
There is a cutout in the lower radiator shroud that it slides into so that wires going to fan are inside shroud, then the top piece of shroud goes back on to hold it in. More or less, been 6-8months since I took it apart last.
ROn
Old Jan 12, 2022 | 12:29 PM
jahummer's Avatar
Many thanks for that. I felt about and indeed there's a hole just below in the support but haven't figured out how to secure it. Any recollection on which way to go about it? Does anything need to be removed first? Not surprisingly the main dealer did that when they replaced the AC system recently.
Old Jan 13, 2022 | 03:18 PM
jahummer's Avatar
I removed the top shroud and found the slot the connector slides into. So frustrating how so many things are returned with screws/bolts missing, clips missing, parts broken and others not put back together correctly every time it's returned from service.
mln01
Apr 25, 2026 07:53 AM
Alex_M
Jul 16, 2024 03:08 PM
RA021226
Sep 14, 2021 07:55 PM
Externet
Dec 12, 2015 04:44 PM
acg
Jul 14, 2014 06:03 AM
