‘15 LR4 // OEM Dash parts
Old May 24, 2021 | 01:15 PM
Poinssixoneeight's Avatar
3rd Gear
Default ‘15 LR4 // OEM Dash parts
Looking for a good resource for interior parts. Need to replace things like:
Start/stop button
left centre console vent
aluminum trim around and between audio dials
high gloss door trim panels
Been hunting for a week now and have found bits, but not all. Love to know where to go.
cheers.
Old Aug 25, 2021 | 05:35 AM
bidoulatt's Avatar
Banned
AC shuts off- The metal contact on the sliding switch for fan 4 is weak and not suitable for the load, common complaint. Pull the switch and had a bit of solder to it- when you have it off you’ll see what I mean. Cruise control- 1) Vacuum pump under headlight by jack, controlled by ecu behind glovebox, vacuum system hoses can be followed from pump to pedals, sometimes they’re split- just replace. Sometimes vacuum boot on throttle housing splits so won’t hold pressure. 2) Two switches ( little actuators) attached to the top of brake pedal and clutch pedal used to disengage the system, some Kodi nox times they pop out of their housing, sometimes they break. 3) Ecu’s known to not be great, should be able to find one on easy- google a discovery 1 cruise control test- there’s an easy test you can do with the multimeter and a 12v supply to figure out the fault.
Geo
LR4
Nov 8, 2021 11:51 AM
mshamilton
LR4
17
Sep 20, 2021 09:07 PM
richs
Aug 7, 2018 07:44 AM
arcteryx33
Jun 4, 2018 09:41 AM
disco3ricky
LR4
Sep 15, 2013 11:28 PM
