2000 Discovery 2 CLD lever came today!
on
The round arm that hooks to the Hi/low shifter arm on our D2, will need to be bent to fit it. Be careful when doing this, I had a friend here i Denver break the arm in the process of bending it. Some people will also buy a D1 Hi/low plate to replace the one on their D2, this eliminates the need to bend the arm making it more of a plug and play.
When done you will like all the extra traction you get when locked up, have fun.
If you cannot locate one and go with the "manly" way
![Stick Out Tongue](https://landroverforums.com/forum/images/smilies/peaexB2.png)
Be glad you didnt have to take apart your t-case...i learn the real hard way....just had to have that 03 black on black...
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
I took out the shift locking solenoid when I put the shifter in my 99. It was not letting me shift in to low. I read on here they go bad so better not to take a chance and be stuck in low away from home. It keeps you from shifting into low while moving. I just don't shift on the fly.
This would be a good time to remove it.
bullcrew
01-11-2012 12:10 PM
