3 inch coil lift
Old Mar 6, 2012 | 10:18 PM
parksy's Avatar
Default 3 inch coil lift
so ive got a 2 inch lift on my d2 but want to change to 3 , for new tyres soon . anyone out there got a 3 inch lift and was it straight forward or did you have to extend brake lines etc . any help is good help
Old Mar 8, 2012 | 06:24 AM
turf63's Avatar
Def have to extended brake lines. (get em at underground rovers for like 90) def need longer shocks or lowered towers/mounts. Probably need a front drive shaft (get a woody off will tillery for 325 shipped) may need caster corrected swivels or cranked radius arms.
I'm in the middle of doing a true three inch lift right now and ditching the fzj lift and spring spacer setup.
OME 763 springs in the rear (constant load heavy duty rear) and OME 764 up front (medium load rear springs) 3-3.25"
Old Mar 8, 2012 | 06:25 AM
turf63's Avatar
My bad. You have a d2 spring numbers might be different for uou
trialrun
Nov 11, 2014 08:41 AM
Joebern
Jun 21, 2011 05:09 PM
b_woodroaster
Nov 5, 2010 08:54 AM
jycsalas
May 21, 2009 09:15 PM
morfa
Aug 27, 2006 01:22 PM
