3 inch coil lift
so ive got a 2 inch lift on my d2 but want to change to 3 , for new tyres soon . anyone out there got a 3 inch lift and was it straight forward or did you have to extend brake lines etc . any help is good help
Def have to extended brake lines. (get em at underground rovers for like 90) def need longer shocks or lowered towers/mounts. Probably need a front drive shaft (get a woody off will tillery for 325 shipped) may need caster corrected swivels or cranked radius arms.
I'm in the middle of doing a true three inch lift right now and ditching the fzj lift and spring spacer setup.
OME 763 springs in the rear (constant load heavy duty rear) and OME 764 up front (medium load rear springs) 3-3.25"
b_woodroaster
Nov 5, 2010 08:54 AM
jycsalas
May 21, 2009 09:15 PM
