3 inch suspension lift
Old Oct 24, 2007 | 02:35 AM
landunit's Avatar
Default 3 inch suspension lift
Hi Guys, New to this forum but not land rovers, reacently sold my beloved S IIA and got a disco series 1 with a 300 moror (tdi) and a 380 gearbox, i want to fit my previous tyres to my new landy, but i know i needed to lift my suspension by 3 inches on the S IIA, i was just wondering if it is as easy on a disco and a S IIA, just coil's and shocks, or will i need to be replaning more? (ie: control arms) i am aware of the Brake lines needing to be changed. any help from somone who has lifted a disco 3inches would be much apprecated.
Thanks Shaun
Old Oct 24, 2007 | 09:25 AM
okdiscoguy's Avatar
Default RE: 3 inch suspension lift
Haven't lifted, and not too sure, But I do know that if you do the OME 2" lift, you don't have to change anything....
Might post this in the Discovery section. I am sure someone on there has done it...
Old Oct 24, 2007 | 01:28 PM
If you want a full 3" lift, you probably aught to look at, http://www.rovertym.com/
Steve make a 2" that is nearly 3"s tall. You can also use the OME colis and achieve nearly as much lift.
Either way it is easy.
Old Oct 24, 2007 | 08:44 PM
ajh's Avatar
ajh
Until you do the lift you won't know how much your castor is out of spec, Rovers arrive with all kinds of build differences from truck to truck. If you're more than 3 degrees out you'll want to also put in corrected arms. You'll also want to consider going double cardon drive shaft in the back instead of the rotoflex if you experience any vibration/premature wear issues with the rotoflex.
Old Oct 29, 2007 | 02:47 AM
landunit's Avatar
Thanks Guys, that rovertym has some nice little goodies.
Old Nov 30, 2007 | 10:12 PM
rovernit's Avatar
7th Gear
We here in Australia don't worry about caster correction kits for the D2 all that much I think anything 4 inch and over its a must and 3 inch and lower I wouldn't worry about I have 5 inch lift and do need one, when some one develops one that's one piece that is [:@]
Old Nov 30, 2007 | 11:19 PM
llesra's Avatar
i have 4" on my D1 and if you want 3" on yours, youll want to change out the control arms. the steering with the stock arms is manageable but new castor corrected arms just steer so much better. i got bad vibes from the stock driveshafts so i changed them to a double cardan in the front and changed the rotoflex to a u-joint in the rear. new rear arms fixed the pinion angle so the transfer case and diff are parallel to eachother. i was vibe free to 90 mph until i put in a new rear axle, but probably wont do that. if you want to run long shocks, youll need new brake lines too. i installed everything myself at home with basic tools. just be prepared for some rusty bolts!
Old Dec 1, 2007 | 06:54 PM
rovernit's Avatar
7th Gear
andchunked knuckles
gulfcoastgorilla
Jul 9, 2012 08:46 PM
rrhyne
Jul 20, 2011 05:56 PM
Joebern
Jun 21, 2011 05:09 PM
Emperor_MA
Jun 15, 2011 11:21 AM
morfa
Aug 27, 2006 01:22 PM
