ARB bumper, under side winch mounting
Old May 20, 2019 | 10:26 AM
gc3's Avatar
gc3
Default ARB bumper, under side winch mounting
Hi guys,
my disco1 came with an ARB front bumper, with a Warn XD9000 mounted under it.
the wind direction on the barrel of the winch is obviously wrong (would cause extra strain on the bumper and mounting bolts)
but it appears there is some metal on the bumper itself which would interfere with the line leading to the fairlead if i wind it correctly.
Any thoughts on why?
does this winch have a line too long on it for this bumper? (seems strange)
see pic below, you can see the slightly rusty metal where the line would rub if i wound the drum correctly.
This would kink the line and cause a lot more friction.
the easy solution is to cut that metal lip out
(ignore the wires, obviously it is not hooked up yet)
Old May 21, 2019 | 07:54 PM
fishEH's Avatar
Is that a winch tray?
Old May 21, 2019 | 09:27 PM
My guess is it was a non-winch ARB Bumper, that someone made into a winch bumper
Old May 21, 2019 | 10:23 PM
robertf's Avatar
I think you have the steering guard bar on backwards
http://www.4x4proyect.com/pdf/arb-3432050.pdf
Old May 22, 2019 | 06:06 AM
gc3's Avatar
gc3
the ARB pdf robert linked below describes it as a winch mount cradle
I don't think so, seems to have too many features specific to a winch and the mounting holes/fairlead mount/hole look better than a typical backyard hill billy drill job
i even have the control box mounted to the bracket shown in the pdf
thanks for the link, i actually am missing the steering arm protector entirely it seems, along with the winch guard (basically a skid plate)
looks like the gearbox and motor end have been rotated correctly on this winch already too.
it seems to have all the correct parts, still not sure what was intended with the winch mount cradle
Old May 29, 2019 | 06:41 AM
gc3's Avatar
gc3
got a response from ARB directly, they say the upper sketch i made in the post above is correct.
Not how I would have done it, but i guess if they say it works, it works.
I will continue as is.
Old Oct 16, 2019 | 09:56 PM
loanrangie's Avatar
That is the correct mounting orientation for a disco fitted with airbags but it doesnt look right to me, pretty sure the angle on my cable wasnt that steep.
Is it possible that the cradle is fitted the wrong way around ? i know my winch sat further back than yours, in Aus not all D1's had airbags so winches mount directly to the bar.
Old Dec 29, 2019 | 09:15 PM
The rover shop's Avatar
I also didn’t like the mounting points on my disco1 ARB so I cut up an older winch mount tray and welded it into the arb...now it’s up the right way and pulls straight..was a pain but I didn’t like the way the winch was retaining the water being upside down...plus it was a pain to get to the release lever..
fosterjd79
Aug 25, 2016 07:53 PM
Shiftonthefly1
Jul 30, 2015 05:25 PM
Drillbit
May 13, 2014 10:32 AM
humroot
Mar 21, 2012 11:39 AM
blast20
Feb 15, 2010 10:25 AM
