Ash Tray and Change tray stuck in?!
Old Sep 7, 2011 | 05:35 PM
sickws6's Avatar
Default Ash Tray and Change tray stuck in?!
Any modification or anything I can do in order to make the ash tray and change tray function the way they should? I am assuming they are suppoded to spring out after pushing them in to release the stop or something. thanks.
I have since found the cause and made a write up in the dico II section. Search it and you will the write up.
thank!
Old Sep 7, 2011 | 05:51 PM
tweakrover's Avatar
Spray something in there, old soda tends to glue them in place
Old Sep 8, 2011 | 09:43 PM
atancreti's Avatar
The change tray doesn't move. Its a real monster to take out (DID THAT TONIGHT) the ash tray does spring out. You should be able to push it in about 1 cm and then it will spring back 3 cm or more...
Old Sep 15, 2011 | 11:44 AM
JEFIII's Avatar
Default Change tray fix
Look in the Disco II section...there is a write up on how to remove and repair the trays. Hope this helps. JF
Kevin Cocksner
Apr 29, 2015 07:51 PM
ImQuattro
May 1, 2014 08:36 PM
Zonk872
Sep 12, 2011 01:22 PM
collin Barrows
Aug 28, 2011 07:13 AM
