I have a 95 range rover lwb, which has brake issues. I may need to replace the accumulator. Is there a way to retro fit standard brake to the range rover? I only drive the rover at home.
First, post something like this in the Range Rover section, you'll get more response.
No, you would spend a fortune trying to convert your brakes over, just change out the accumulator and be done with it, it is an easy job.
