Built rover v8s
Old Jan 24, 2020 | 09:35 AM
The rover shop's Avatar
Most disco2s here in the USA don’t have CDL...!!!
Old Jan 24, 2020 | 09:40 AM
Friday Night Disco's Avatar
Good point, this might work if you try the above steps using low range instead of CDL.
Old Jan 24, 2020 | 09:41 AM
Originally Posted by Sixpack577
If you have TC off, and rengage the CDL, does the TC still remain off?
No idea, I can check when I get home
Old Jan 24, 2020 | 10:13 AM
JUKE179r's Avatar
Just to add... All the facelift Disco 2's overseas don't have the 4.6L V8. Only NAS had them.
Old Jan 24, 2020 | 11:58 AM
Sixpack577's Avatar
....mine does
Old Jan 24, 2020 | 01:45 PM
Richard Gallant's Avatar
Smile
My 04 does
Old Jan 24, 2020 | 02:56 PM
ACEngineer's Avatar
There’s a guy from England on a Facebook group telling me the d2 is limited to 251 hp at the wheels due to traction control cutting power. Can anyone shed some light on this? I thought our tc only activated the brakes?
he claims he has 350hp from his motor on an engine stand but is only able to put 251 down to the wheels because of the tc. I could see 300 at the wheels after parasitic and driveline losses.
I'm surprised they didn't just pull the TC fuse/relay if that was the problem. I would guess that low number has something more to do with the Motronic ECU and tuning rather than the TC. TC has worked fine for us with 300hp/335 ft-lbs, but that's not running the engine on the Motronic.
Old Jan 25, 2020 | 04:22 PM
I just validated that yes the TC stays off with CDL reengaged.
So again...the trick is to engage CDL and turn the engine off. When you restart with CDL engaged, the TC is turned off and will remain off until you disengage the CDL, turn the engine off, and restart engine
Old Jan 25, 2020 | 07:25 PM
Sixpack577's Avatar
Right on
Thanks!
Old Apr 20, 2020 | 01:51 PM
11chuck's Avatar
If I'm not mistaken, that trick only works on the first SLABS ECU version, on the later 03 and 04 revisions it does not do that.
