DC-DC Charger Setup in a Disco 2
Old Apr 22, 2020 | 03:48 AM
markdeg's Avatar
Default DC-DC Charger Setup in a Disco 2
Currently working on installing a second battery and DC-DC charger in my Discovery 2. My requirements are that I do not lose offroad capability, and that I have an inverter mounted in the boot. I also do not want to loose any boot space, so the new battery will go instead of the compressor, as mine is now converted to rear springs.
Does anyone think of anything why the following diagram would not work (i left required fuses out of the diagram for simplicity). Mostly interested in your opinion re wire thickness and if it would be ok to connect live wires from the dc dc charger and load to the battery through a distribution block rather than at the battery terminal. Anther question is, do I need to run earth wires or can I use the body/chassis for earth? maybe I can add a few more earth straps to improve the earth throughout.
Old Sep 22, 2020 | 11:23 PM
snowmansgarage's Avatar
I'd recommend a breaker near the starter battery on the line that runs to the DC/DC charger (appropriately sized), also put your 100a switch/distribution as close to your Leisure battery as well.
DakotaTravler
Feb 10, 2019 02:14 PM
RawFaith
Feb 16, 2017 10:42 PM
Rufflyer
Dec 21, 2014 09:26 PM
LR03NJ
Nov 12, 2012 03:16 PM
thomas22
Jul 25, 2009 04:35 PM
