Deka Intimidator AGM Battery - My Thoughts
Old Jul 30, 2019 | 02:25 PM
RickyN29's Avatar
Default Deka Intimidator AGM Battery - My Thoughts
Just wanted to share, last year I added an aux battery on my LR3. Did homework and it seemed Deka Intimidator AGM batteries were a solid option. I got the 9A47 rated for 60Ah. Only running an ARB fridge. (Averaging ~1-1.5amp draw per hour). From day one, 12 hours of run time and I was down to 11.8v. Now, a year later, I am lucky to get 6 hours before it drops to 11.5v. Going to replace it under warranty but still bummed that I dropped $200+ on a battery that's worse than a cheapo!
A real disappointment as previously just running a Walmart or Costco SLA battery would run the fridge 24 hours with no noticeable dip in voltage.
Old Aug 26, 2019 | 01:06 PM
logan_gibson's Avatar
How is it charging? Short charging it often can cause an early failure.
Old Aug 26, 2019 | 01:23 PM
RickyN29's Avatar
When in use with the fridge, it is connected to my 100w solar system. When not, it is connected to the vehicle battery/alternator via a battery disconnect system (also a battery maintainer when parked long term).
aemnky606
Jun 4, 2017 11:36 AM
Chris Schafer
Jun 6, 2016 12:32 AM
ebg18t
Oct 3, 2012 02:45 AM
primo
Mar 29, 2011 06:55 PM
2000 Disco 2 SD7
Jan 25, 2009 02:59 PM
