Discovery Seat Position For Tall People
Old Jun 7, 2019 | 05:14 PM
WeekendWarriors87's Avatar
Default Discovery Seat Position For Tall People
Hello to everyone else out there with a Disco 1 (or 2, assuming its roughly the same). Anyone else else around 6' tall have an issue driving these? I currently have my seat all the way back and my driving foot is basically vertical when cruising at 80 kph, its very uncomfortable. Also, anyone else feel like the seat is too high? I cannot see stoplights when I stop at a reasonable distance, and the rearview mirror blocks half of my vision. I am maybe a bit weird because I sit up very straight and not laid back when I drive, but I feel like I have to chop and lower the seat brackets by an inch or 2 because its bugging me like crazy. Anyone else have tall people issues in these or is it just me?
Old Jun 13, 2019 | 07:09 PM
KoolKatKaleb's Avatar
4wd High
I'm 6 too and noticed I was losing feeling in my foot while driving ~45min at 60mph yesterday. I sit in a similar position, but I think I'm going to start experimenting with different positions.
I was starting to think that the position of the throttle pedal was high and pressure needed to compress the pedal was excessive, not sure if that's just my imagination.
Old Jun 14, 2019 | 12:48 PM
Glad someone else finds this. I think I am going to move the seat bracket back 2" to give me a little more room and move the rearview mirror up 3" so that it doesnt give me a huge blindspot anymore.
Old Sep 5, 2019 | 02:20 AM
BierNut's Avatar
Same here with my 95 D1 5 spd the past 20 years not seeing overhead traffic lights above the roof line. Heck i'm only 5' 10 1/2" but feel taller driver's problems.Thinking it bwas just me? British people must be short people vs us Americans.
Recently picked up (last weekend) at Pick-n-Pulls 50% off Labor day a pair of clean condition and color cloth front seats with bases off a 94 D1 to install in the 95 of tan leather seats and interior.
Planned on cutting down and reweld the driver's seat frame thinking 1" to 1 1/2"the maximum I can lower as the curve of the seat frame will become an issue. Thinking of removing an extra 1/4" from the frame vs front for better front of seat support. I'll lose clearance for the CD player but never use it anyway. Another LR garage shelf item. .....~~=o&o>......
Old Sep 5, 2019 | 02:33 AM
BierNut's Avatar
The seat mounting locations are at the frame support wings two locations also supporting the body hence your opening a can of worms relocating the frame farther back.
Adding metal strips bolted down with welded studs sticking up a couple inches rearwards is one solution, did it to a BMW for my 6'4" tall son.
Removing the seat frame from the seat is a PITA as it takes an odd sized Torx to unbolt the screws. Ended up taking a 3/8" drive T45 Torx, Dremel with cutoff wheel cutting the Torx valleys deeper plus grinding the peaks lower to tightly fit those odd ball sized Torx bolts. Damn odd balled size Torx the British used. They used Loctite so another battle breaking them loose, a heads up what I have found......~~=o&o>.......
Old Sep 5, 2019 | 04:09 AM
JUKE179r's Avatar
Remove your wallet from your back pockets when driving. It can pinch nerves making your leg and/or foot numb.
Old Sep 5, 2019 | 08:16 AM
thanks for the input, didnt know that the seat supports were structural. I will probably add some rails to the top of them in order to shift the seat back. I will try to remember to report back in the winter with what I come up with.
jringeno
Jun 26, 2021 04:54 AM
NewToTheTwo
May 9, 2019 07:10 AM
wrynp
Feb 13, 2016 02:51 PM
SinisterMoose
Jun 9, 2015 02:10 PM
NiteTrain
Oct 26, 2011 10:58 PM
