Disco 2 Lift Advice please
Old Jun 9, 2020 | 02:55 PM
TuffDeck's Avatar
Default Disco 2 Lift Advice please
Hey all,
So I'm about to do a lift on my Disco 2. I have the Terrafirma 3in lift from lucky8, I have the brake line extenders, the sensor extensions, the steering dampener, and a drive shaft.
Does anyone know if I need anything else?
The following questions I'm not sure if even apply to the discovery 2 just general research on 4x4's. I may be way off base with the questions so please bear with me its just information I've gathered in general about lifting trucks.
I've seen on other 4x4's that people swap the sway bars is that needed for the disco 2? Same for radius arm is this a need on a discovery 2? is the a need to change the castor bushings or castor correction arm, what about panhard rods?
Thank you for your advice.
Old Jun 11, 2020 | 10:27 AM
Art H's Avatar
I cannot give you advice on what to add when lifting, all I can say is that be prepared for it to be more than 3 inches. The disco2 has some very soft springs from the factory and they sag -a lot. I replaced mine with the Bearmach HD stock height springs and the truck sits a good two inches higher than before. My 2003 had 112,000 miles on it when I did the work. And here I thought all the new SUVs and pickups were getting taller!
Old Jun 15, 2020 | 05:26 AM
TuffDeck's Avatar
thanks for the heads up, Ill start a build thread if you or any other user wants to see the change.
cybercop
Mar 22, 2021 11:18 AM
collector87
May 16, 2012 05:11 PM
DiscoWest
Aug 20, 2010 08:08 PM
skatelove303
May 24, 2009 09:23 AM
ajh
Nov 3, 2006 07:27 PM
