Disco I backup lights upgrade?
Old May 27, 2007 | 03:25 PM
Sooners's Avatar
Default Disco I backup lights upgrade?
My 98 Disco has very dim backup lights and dark tint on the glass.
Anyone upgrade their lights? Hi-output bulbs?
Thank you,
Mike
Old May 27, 2007 | 04:12 PM
Default RE: Disco I backup lights upgrade?
I designed a rear bumper for my 99 D2 and didn't want to cut holes into the 2X4 box steel bumper face so I added a Hella Utility light, with a 100 watt bulb, mounting it to the plastice housing that is above the license plate. I have to tell you, I have more then enough light now.
Mike
Old May 27, 2007 | 08:00 PM
fire1427's Avatar
I picked up a set of 55 watt reverse light bulbs ... Have not installed yet (want to check for proper fuses ect)
Old May 27, 2007 | 08:46 PM
You shouldn't need to change the fuse, I am using 1 100 watt bulb in place of the 2 standard 15 watt bulbs andven't had any problem.
Remember you can bump those 55's up to 100's very easily.
Mike
Sooners's Avatar
ORIGINAL: fire1427
Let me know howthey work out.
Mike
Old May 27, 2007 | 09:14 PM
fire1427's Avatar
we threw them in a couple of the police cruisers , they are BRIGHT ... I'm also concerned about melting the plastic covers
bigjerel
Apr 17, 2010 10:04 PM
carnut
Dec 6, 2008 04:55 AM
Max_A6
Aug 25, 2007 11:46 PM
arianamini
May 1, 2007 03:53 AM
sharp21
Audio/Visual Electronics
Apr 14, 2007 10:53 AM
