disco lift
Old Oct 18, 2006 | 01:12 AM
put_the_winch_away's Avatar
3rd Gear
Default disco lift
was wanting some idea of how high a 1994 disco can be lifted. without going overboard. it will be used 80% of the time onroad. what suspension lifts have you guys seen work.
Old Oct 18, 2006 | 01:58 AM
llesra's Avatar
Default RE: disco lift
i have a 94 with 4" of lift which needs lots of extras. 2" can be had with springs and shocks. rovertym and old man emu make good springs.
Old Oct 18, 2006 | 12:54 PM
Consider the OME shocks and springs, they will give you a good 2' lift for both road and trail.
Mike
Old Mar 20, 2007 | 07:18 AM
disco@datowers's Avatar
3rd Gear
Hi there. i'm a newbie to Land rovers and recently bought a 2 litre MPI, 94 disco. It's done about 196,000 kilos and came with sagging suspension. Even the self levelling ball joint needs replacing. I'm looking at changing the suspension and steering damper (if thats what you call it) Looked at OME, not very recommended here in Malaysia as most of them develop leaks after about 3 months. This is whats been said by the shops. Another brand is tough dog, also OZ and then there is Iron man, another OZ brand thats been around for about 5 years (as far as i can remember) please visit http://www.ironmansuspension.com/
My question is, has anyone here on the forum used this brand before orelse even heard of it? I'm looking at foam cell type shocks from their range. Am also concerned that the ride may become harsher after the change.. Please advice.
Old Mar 20, 2007 | 07:23 AM
3rd Gear
oops! double post
Old Jan 18, 2009 | 09:18 PM
scadjoey's Avatar
Hey there. Just wanted to see if anyone has had any experience with this lift http://www.toddcosuspensions.com/landrover.htmland was planning on the 2.5" kit. will there be any problems with the driveline angles, caster/camber issues, clearance? may have to go with the 2" version. also if I go with the OME springs, do I necessarily HAVE to buy new shocks? I dont really need that much articulation so...
Old Jan 18, 2009 | 10:02 PM
handsome rob's Avatar
While coil spacers can be great on new springs they are a bad idea on old ones. I would not recommend them. You will want 2" longer shocks too since even though you may not need the articulation now you do not want the shock being the limiting factor if you ever do. Unless your shocks are new anyways you can get a shock extensionkit that basically lowers or raises it the needed 2", chance are you need new shocks anyways so just buy the right size. If you feel you need the lift and do not have a lot of cash you can go with less expensive springs and shocks, just do not expect to have the best ride ever. Besides the ride factor is subjective anyways, what I think is acceptable you may not.
Good Luck.
Old Jan 19, 2009 | 07:05 AM
You only use a set of spacers after install a H.D. set of coils and shocks, other wise you will have even a more top heavy vehicle off road.
Just go order either an OME or RTE lift and you will have it right and love the difference.
Old Jan 19, 2009 | 11:52 AM
scadjoey's Avatar
cool thanks guyz. BTW Mike the Seafoam application worked awesome. Thanks for you help.
Old Feb 12, 2009 | 08:23 PM
KarenCaren's Avatar
I think the best way to have a lift is to go 2" suspension and 2" lift. Going that way will not give you a hard time handling your wheels since you have too much time on the road.
________________
radiator
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
