Freelander Overflow Tank Upgrade
Old Jun 20, 2017 | 07:33 PM
heluvashot's Avatar
Default Freelander Overflow Tank Upgrade
Hi all. Finally got sick and tired of the cracking coolant ball! I chose to go with a Ford unit from a 2003 Ford Focus. It was an easy swap. Used the factory Ford bypass hose cut down to adapt to the factory Rover hose. Also plugged one extra hose barb on tank. The Dorman part # is 603-216. The Ford tank is made for a 20 PSI system, so had to re-use the Rover cap at 16 PSI. Hope others can use this info.
Old Jul 16, 2017 | 02:20 PM
Vktr's Avatar
I'm planning on replacing mine soon too I found an Allisport aluminum expansion tank that they make for the D1 and Range Rovers but I don't know how well it will adapt for the D2. Here's the one I'm talking about.
Old Jul 27, 2017 | 07:54 PM
Vktr's Avatar
Did it, looks wayyyyyyyyy bettttterrrr.
ewatk
Jul 9, 2020 05:17 PM
rrbc
Nov 13, 2009 01:40 AM
Rangie_
Aug 7, 2009 08:03 AM
bigfun
Dec 13, 2007 04:23 PM
pompano
Nov 5, 2006 10:29 AM
