KAM Ring and Pinion Press Release
Old Oct 30, 2009 | 10:40 PM
Fivespddisco's Avatar
Default KAM Ring and Pinion Press Release
Rover Dog is very proud to announce the Official Release of KAM gears in the USA. You may ask yourself, Why is this so important to the Land Rover community? Well, we have 8 game changing reasons that are sure to change your mind.
1) Reverse cut fronts!
2) The same price for standard and reverse cut gears!
3) (4.10) and (4.75) gears for you P-38 Lovers!
4) Not 1, not 2, but 3 choices of classic Rover gear ratios for you! (3.8) (4.10) (4.75)
5) Dyno static tested by Land Rover Engineers to be stronger then stock, (3.8) 70% (4.10) 25% (4.75) 50%
6) Each gear set is matched and lapped-in by a Gleeson lapping-in machine for optimum set up
7) All gear set are made from certified steels, dedicated drop forgings and carefully controlled heat treatments.
8) Best of all they are only $328 a set!
We at Lucky 8 are striving to be your first choice for Land Rover drive train. Let us know what we can do to earn your business
for more info http://lucky8llc.com/Search.asp?Manu=KAM
OffroadFrance
Off Topic
Oct 5, 2014 07:29 AM
Fivespddisco
May 28, 2010 12:44 PM
Fivespddisco
Off Topic
Feb 2, 2010 06:11 PM
hazletbassist89
Oct 19, 2009 09:44 AM
Ironman472
Mar 11, 2009 12:11 PM
