LED Light Bar - Installation Help Needed
Assuming you have the relay all figured out... I drilled a small hole next to the point where the wiring harness enters the firewall above the passenger footwell. Most auto shops have a selection of rubber grommets you can use.
If you haven't figured out the relay go to a shop. I'd suggest a high capacity relay, a small fusebox, a switch (or use one you have already) and some thick wire. Also... and Mike is touching on this.... watch your amps and consider wiring it like the fogs so if you have brights on the light bar goes off.
It just occurred to me that if you have secondary air injection you might have to move a component aside to see the spot.
