lift kit
Old Nov 14, 2014 | 06:52 PM
rovermadness's Avatar
8th Gear
Default lift kit
I have a 96 se7 V8 disco, has a 2" suspension lift. I'd like to do a 2 " body lift also. I found the blocks to suit, what else do I need to complete this, extended brake lines I know I'll need , but is there anything else. And is it still legal to dive on road?? Any advise welcome.
Old Nov 14, 2014 | 07:48 PM
dusty1's Avatar
You'll want to fashion some brackets to bring up bumpers...or maybe you can buy some. Not sure where to buy
I'm sure it is legal
Old Nov 14, 2014 | 08:36 PM
fishEH's Avatar
Why do you want a body lift? You can run 35's on a D1 without a body lift.
Old Nov 14, 2014 | 08:55 PM
jafir's Avatar
Body lift will let you fit bigger tires without changing suspension geometry. I don't know why they get such a bad reputation.
Old Nov 15, 2014 | 10:51 PM
8th Gear
I'm currently running 32" and they scrape at full flex. Have ordered 33 don't mind cutting guards but having a lot of trouble locating flares
Old Nov 15, 2014 | 11:00 PM
8th Gear
Thanks mate. I hadn't thought of bar heights.
Old Nov 16, 2014 | 07:14 AM
Buddy Lee's Avatar
I don't personally like body lifts. But If you are going to do it for a 2" body lift, to do it right you'll need extensions for the rear seat belt mounts, the diff lock shifter, radiator suports, steering linkage and probably a few other items. As well as the already mentioned bumpers.
You can probably make due without some of these items but you'll need to do something to accommodate those items. I think I do have some 3" extensions for the radiator and Diff lock laying around someplace from a truck I scrapped.
caymandrew
May 9, 2015 10:05 PM
Bostonc16
Mar 7, 2015 10:32 AM
caspian
Feb 19, 2011 06:41 PM
majrmike
Oct 9, 2007 03:13 PM
studlee
Aug 8, 2006 10:29 PM
