Range Rover classic bumper
Old May 18, 2021 | 11:21 AM
Robert Tripp Norwood's Avatar
7th Gear
Default Range Rover classic bumper
A few days ago i went out to buy a bumper for my Range Rover classic and this bumper was thrown in. I have never seen this bumper for the classics and I cannot find anything about them. If anyone could help thanks. I attached a picture.
It’s a rear bumper that folds up and down for the cargo doors.. hell, it was still in its box from 1987. That’s all I know about it. It was for a 1987 RRC.
this picture is not my picture. This is the only picture I have found of this bumper.
Old May 18, 2021 | 02:11 PM
Art H's Avatar
I can see why nobody bought or used it, it is on the ugly side of the spectrum. Now, if it folds out "flat" from the bumper, I bet you could make a table that sits on atop it for camping or other uses.
Old May 18, 2021 | 04:39 PM
stillruns's Avatar
Tailpipe looks worse than the bumper.
Old May 19, 2021 | 04:46 PM
OverRover's Avatar
That's a BEARMACH BA-004, but IDK if they still sell it anymore.
You can check here >> https://bearmach.com/
Old May 19, 2021 | 08:37 PM
7th Gear
hey! Thank you so much for this. I truly wish that I could find some type of install instructions just to have them. I have been looking everywhere!
Old May 19, 2021 | 09:54 PM
OverRover's Avatar
IIRC these never came with instructions, but keep in mind the last time I saw this bit was when I tossed 3 that just took up garage space.
With that said just shoot BEARMACH an email and if they have instructions I'm sure they will send you the PDF.
Good Luck!
Old Jun 15, 2024 | 11:03 PM
Admiralnahohkta's Avatar
Default Bearback RRC Nudge Bar Load Carrier
Thanks both of you for posing this. I also have a RRC that had this rear guard thrown in. I cannot find instructions, however I am installing it. It came with the original mounting hardware. The rear bumper needs to have two 7/16" holes drilled into it. The brackets for this Nudge Bar bolt to existing mounts on the frame next to the gas tank, and the other end sits OVER the rear bumper, and bolts through the holes that need to be drilled. The holes are vertical and line up with holes in the frame horn ends that are normally covered by the top channel of the stock bumper. These top holes are a blind hole, because the frame horn ends are totally boxed. I will see what kind of nut certs may work.
Bearmack BA004 Rear nudge bar and carrier.
That being said, when the Nudge Bar brackets sandwich the bumper you get a pretty clean fit...for a big tubular thing hanging off your rear tailgate.
LR03NJ
Jun 29, 2018 11:05 AM
KingKoopa
Sep 20, 2017 05:20 PM
steb4680
Nov 14, 2014 07:59 AM
calebbo
Jan 29, 2014 10:38 PM
nate2k5
Mar 2, 2012 07:35 AM
